9 years ago0-15 counter
Hi Guys, Can anyone help me i am nee to altera programming. Can anyone help me i am trying to write an up and down counter that counts from 0-15 with 2 bushbuttons and 2 7 segments display ...
9 years ago --- Quote Start --- I am writing a vhdl code and i cant figure it out --- Quote End --- Which step are you stuck on? Pick something simple. For example, start with the 7-segment decoder. That circuit can be combinatorial. The component input is 4-bits and the output is the 7-segment 7-bit value. Draw images of the digits 0 through F displayed on a 7-segment display and create a table of which bits need to be on or off. See if you can figure out how to implement that in VHDL. Don't worry if you cannot, just post the table (photo of paper is fine) to show you understand and tried. Cheers, Dave
