msager
2 years ago.V files not showing up in project navigator hierarchy tab
Hello, In my project only the top level .bdf file is showing up in the project navigator hierarchy tab. For some reason the .v files are not showing. I am attaching a picture of the .bdf file. I sa...
- 2 years ago
The compilation doesn't finish I let it run for a long time. I am not sure what the issue was but I made a new project and re-did everything and it worked.
msager
2 years agoWhen I try to "Start Compilation" it stops at "Analysis and Synthesis" phase. I also don't get any errors just warnings.
- sstrell2 years ago
That screenshot shows that the compiler is still running. You have to wait for it to finish.
And you should check the warnings against your design to see if they are acceptable or if you need to fix something.
