msager
2 years ago.V files not showing up in project navigator hierarchy tab
Hello, In my project only the top level .bdf file is showing up in the project navigator hierarchy tab. For some reason the .v files are not showing. I am attaching a picture of the .bdf file. I sa...
- 2 years ago
The compilation doesn't finish I let it run for a long time. I am not sure what the issue was but I made a new project and re-did everything and it worked.
KennyT_altera
2 years agoCan you check if after you run the elaboration still facing the problem? If yes, can you attached your design to us?
