msager
2 years ago.V files not showing up in project navigator hierarchy tab
Hello, In my project only the top level .bdf file is showing up in the project navigator hierarchy tab. For some reason the .v files are not showing. I am attaching a picture of the .bdf file. I sa...
- 2 years ago
The compilation doesn't finish I let it run for a long time. I am not sure what the issue was but I made a new project and re-did everything and it worked.
sstrell
2 years agoThat's not how the Hierarchy tab works. The Hierarchy tab displays your project hierarchy after you've performed at least Analysis & Elaboration from the Processing menu, which checks your design files for errors and builds the hierarchy based on your connections and instantiations. It looks like you have not run Analysis & Elaboration or full synthesis yet in this design.
