.sof not generated
Hi MWang65,
I'm apologize for late reply. I just realize your issue haven't solved.
I suspect your license expired. Can you provide your license.dat file for checking? And you can also reply/attach your license.dat file in private message to me.
Please let me know when you send your license.dat to my private message.
Thanks.😉
p/s: OpenCore Plus doesn't not support Display Port IP. That the reason why you can't generate the .SOF file.
- MWang657 years ago
Hello, thanks for your reply. I don't have access to the license.dat because we have been pointing to our R&D partner's license server. It may be difficult for me to obtain it.
I found something interesting though. If I generated the example DisplayPort design using Quartus software (17.1), I can generate time-limited .sof from the example design project. This suggests that OpenCore Plus (evaluation mode) is enabled
