.jic file
Hello, everyone. I'd like to ask
I now ask. JIC file, each in its structure has a CRC check, where can I find or provide a document
thank you
- JohnT_Altera
Let me know if you have further queries or feel free to create new forum case if you have any new issue.
- JohnT_Altera
Unfortunately there is no way to determine the jic file as it is only binary file which is used to program into the flash.
- FPGA1
hi
i know
thank you
- JohnT_Altera
Each generation of the JIC file will varies. Not sure if this uniqueness is sufficient?
- FPGA1
hi
Because I want to pass the last generated JIC file to others through this unique "data", and then ensure that this JIC file is the last one I generated and transferred to him.This' data 'can be seen.
thanks
- JohnT_Altera
May I know what type of uniqueness are you looking for?
- FPGA1
hi
I want the data that can prove the uniqueness of this JIC file, just like CRC validation code, can prove its uniqueness
thanks
- JohnT_Altera
Unfortunately there is no way to read the file as it is a binary data.
- FPGA1
hi ,
Thank you very much for your patience in answering the questions. I hope you can give me a suggestion now. Is there any way to identify the uniqueness of JIC files.
- JohnT_Altera
Same with RPD file where it is a binary file. We are not able to released how the format structure as it is confidential.
- FPGA1
Hello
what else can identify JIC and read it as data
thanks
- JohnT_Altera
I make a mistake on mentioning JIC is user readable. Actually JIC is a binary file which is only readable by Quartus. We do not release any document or guide on how to check the file.
- FPGA1
hi,
What about RPD ?
thanks
- JohnT_Altera
JIC is ASCII code which is readable by user.
- FPGA1
Hi
Do you have this document, or know the name of this document, I will try to find it
thank
- JohnT_Altera
Unfortunately we do not have the file to provide the information related to CRC checl.
- FPGA1
do you mean there is no CRC code similar to bin file in JIC? So, is it similar to the data that can prove the uniqueness of the JIC file?
