[ Error ] hw_library.iipx , sw_library.iipx files missing when generating HDL on Platform designer.
Well that's weird. Did you add IP targeted to a different device family than the one you are using? This is possible if the filter in the IP Catalog in Platform Designer is changed.
Other than that, a reinstall of Quartus and C10GX device family may be in order.
- AdityaJain4 years ago
Oh yes, I think I have added an IP which is targeted for Arria 10 and not Cyclone 10 ( 2 IPs, the rest are Cyclone 10 ). Is there a way I can change the target device to Arria 10 for my project?
- sstrell4 years ago
If you're using a Cyclone 10 device as the target for your project, why would you want to change the target device to Arria 10? Instead of doing that, delete the A10 IP and re-add it to the design as a Cyclone 10 GX IP. If this IP is something unique to A10, you won't be able to bring it to C10GX.
