CPaul10
6 years ago[ DE0-Nano ] Question about JTAG Uart & RS232 Uart
Hi
I would like to control DE0-Nano on PC by JTAG UART, also I can command DE0-Nano do something by rs232 UART.
But it seems can't output string through rs232 UART, when JTAG UART is exist in Nios II system.
If I remove JTAG UART IP, the rs232 UART can output string normally.
Is it possible use JTAG UART and rs232 UART at same time?
- CPaul10
Setting STDOUT to RS232 UART
- BoonBengT_Altera
Moderator
Hi @CPaul10,
Per my understanding, output simultaneously to RS232 and JTAG are not possible.
If you do not mind me asking, what would be the use case that required you to do so?
Also for the stdout setting changes to RS232, I believe that is in the BSP editor setting.Warms Regards,
- CPaul10
Thanks for your reply.
My project is work well.
