15 years agowriting/reading sram with cyclone3 in vhdl
Hey, i'm trying to write and read to/from the sram with a cyclone3 fpga on a NEEK. I wrote a little code to check if it's working, but it doesn't and i tried very much around but to no avail. The ...
15 years agoYes the numbers are clock cycles. If you can, try to regroup the address signals together. Then you'll get a single line with the address in hexadecimal form. You can do the same thing with the data.
I think that you need to hold oen low for several cycles. The be_n* signals should also be low when you write. They are used to select which bytes to write in the 32-bit word.
