16 years agoWriting to SRAM/SDRAM on DE-2 board ?
Hi all, I've been working on the Digital Camera Development Kit with a DE-2 Board and a Cyclone II FPGA, and I'd like to write data that comes out of the camera, to the SRAM or SDRAM. I sa...
16 years agoCan you use the external memory without Nios/SOPC? yes, you could use the EMI IP from Altera.
Will this still work if I change FPGA to a different brand? No, the EMI interface is heavily dependent on IO architecture and this is not compatible between different FPGA manufacturers.
