DRim0
6 years agoWould anybody has timing signal graph for HSMC port data communication?
I have Altera DE4 and DE1 FPGA board, and trying to use these as a master-slave combination. So far, DE4 board seems to have problem with it's GPIO ports, so I'm trying to use GPIO-HSTC card to con...
YuanLi_S_Intel
6 years agoIf you are saying about the HSMC usage in general. Yes that document can be used for that. As the pin assignment on the HSMC port is per standard.
If you would like to communicate between 2 devices using HSMC. You will need to figure out which pin is connecting to the device and then you only can design your quartus design with that.
