16 years agoWindows XP Command Shell quits?
All, I'm obviously a beginner with Windows XP and NiosII. I've downloaded the 9.1 releases of the NiosII EDK and Quartz stuff and tried to run the examples. There might be something...
16 years agoOne problem can be that you didn't installed it right. It doesn't run because
it can't find the cygwin.dll or cygwin1.dll file. Select Windows icon in your taskbar and then click Search. Specify there the one of the above files and try to find where it is located on your harddrive. If you can't find it then maybe you didn't install it properly. I have also the NIOS II EDS 9.1 and it works.
