MapleDoi's avatar
MapleDoi
6 years ago
Will FPGA stop working after a huge number of clock pulse. (DE1-SoC)
Hi, I am not sure how to describe the problem to be written in the title. So I have a 150mb dataset in .txt, it looks like:
0.123
0.254
0.956
got like 3 million rows.
I am using the FIFO in sending all data one by one to fpga to perform calculation, it send 20k from HPS to fpga, and on the fpga side it keep on calculating, and once 20k counter is reached, the fpga will output one result to HPS.
Below is the C:
while (j<35)
    	for (k = 0; k<N; k++)
	        fscanf(fp, "%f", &data);
	        data = fabs(data);
	        data = data * bin_scale;
	        scaled_data[k] = (int)data;
	    for (i=0; i<N; i++)
		    	FIFO_WRITE_BLOCK(scaled_data[i]);
	    j++;
	    usleep(1*1000);
	while(!READ_FIFO_EMPTY)
		retdata[m] = FIFO_READ;
		retdata[m] = retdata[m] / bin_scale;
		printf("data %d out %.10f\n",m, retdata[m]);
		m++;
	fclose(fp);
and below is the verilog code:
always @(posedge CLOCK_50)
begin
	if(initEnable == 0) begin
		sram_write <= 1'b0 ;
		hex3_hex0[3:0] <= 4'd1;
		hex3_hex0[7:4] <= 4'd10;
		hex3_hex0[11:8] <= 4'd1;
		hex3_hex0[15:12] <= 4'd10;
		hex3_hex0[19:16] <= 4'd1;
		hex3_hex0[23:20] <= 4'd10;
		data_buffer_valid <= 1'b0;
		HPS_to_FPGA_state <= 8'd0 ;
		FPGA_to_HPS_state <= 8'd0 ;
		Processing_state <= 8'd0 ;
		initEnable = 1;
	end
	if ((HPS_to_FPGA_state == 4'd0) && (!(hps_to_fpga_out_csr_readdata[1])))
	begin
		hps_to_fpga_read <= 1'b1 ;  // read data flag
		HPS_to_FPGA_state <= 4'd1 ;
	end
	if (HPS_to_FPGA_state == 4'd1)
	begin
		hps_to_fpga_read <= 1'b0 ; // zero read data request before data appears
		HPS_to_FPGA_state <= 4'd2 ;
	end
	if ((HPS_to_FPGA_state == 4'd2) && (hps_to_fpga_read == 1'b0))
	begin
		memo[i] <= hps_to_fpga_readdata ; //read the data to memo[0]
		Processing_state <= 4'd5 ; // enter data processing state
		HPS_to_FPGA_state <= 4'd3 ;
	end
	//-----------delay before enter state 0------------//
	if (HPS_to_FPGA_state == 4'd3)
	begin
		HPS_to_FPGA_state <= 4'd4 ;
	end
	if (HPS_to_FPGA_state == 4'd4)
	begin
		HPS_to_FPGA_state <= 4'd0 ;
		if (i == 125)
		begin
			i <= 0;
		end
		else
		begin
			i <= i+1;
		end
	end
	if (Processing_state == 8'd3)
	begin
		Processing_state <= 8'd0 ; //return a data packet
	end
	if ((Processing_state == 4'd5) && (FPGA_to_HPS_state == 0))
	begin
		a <= a + memo[i] * memo[i];
		Processing_state <= 4'd4 ;
	end
	if (Processing_state == 4)
	begin
		Processing_state <= 4'd3; //signal fpga the data is ready to be sent
		data_buffer_valid <= 1'b1 ;
	end
	if ((FPGA_to_HPS_state==0) && (!(fpga_to_hps_in_csr_readdata[0])) && data_buffer_valid)
	begin
		if (|a == 0)
		begin
			k<=a;
		end
		else if(|a != 0)
		begin
			if (j == 20479)
			begin
				fpga_to_hps_in_writedata <= RMS;
				fpga_to_hps_in_write <= 1'b1 ; //write flag
				FPGA_to_HPS_state <= 4'd1 ;
			end
			else
			begin
			end
		end
	end
	if (FPGA_to_HPS_state == 1)
	begin
		fpga_to_hps_in_write <= 1'b0 ; //data wrote, clear flag
		data_buffer_valid <= 1'b0 ; // data sent, clear flag
		FPGA_to_HPS_state <= 4'd2 ;
	end
	if ((FPGA_to_HPS_state == 2) && (data_buffer_valid == 1'b0))
	begin
		FPGA_to_HPS_state <= 4'd0 ;
		if (j >= 20479)
		begin
			j <= 0;
			a <= 0;
		end
		else
		begin
			j <= j+1;
		end
	end
end
div #(64, 15, 0, 0) Div (
.a(a),
.b(j+1),
.quotient(mean),
.remainder(),
.divide_by_0()
sqrt #(64, 0) Sqrt (
.a(mean),
.root(RMS)
My problem is when the program send back to HPS, it could not send back the 32nd data back to HPS. In the seems like on HPS (C code) side it detect no data in FIFO. If I increase the loop to 50, it will send back 49 data instead of 50, but the data after 32nd data are all messed up. So will the fpga stop after working for certain number of clock pulse?
I am sure the C have no problem.
The verilog have no problem as well I think, because if the verilog have problem, the result would have appear on the first few data send back from fpga, instead it appears on the 32nd.
Also, after the program is ended, and I execute it again, then all the data messed up.
[EDIT]
After re-watching few videos, seems like I found the source problem:
Seems like here is the problem, hope someone can enlighten me in solving this problem.
1 Reply
  • Hi,
    Looking at this issue, it might be caused by the timing issue of your design.
    Is the design your own or from a tutorial/ websites that you selected?
    Which Quartus version are you currently working on? Could you share your timing reports in Quartus here?
