What is the maximum Avalon memory-mapped interface data width supported for MAX 10 device?
- 6 years ago
Dear Susmita,
Firstly, no problem for contacting us, It's what I'm here for. Even, me myself is also still learning. Learning process never ends I can say. So, don't be sorry 😊
Interface width : The total number of DQ pins of the memory device.
DQ/DQS group size: The number of DQ bits per DQS group.
Let's say for example your total interface width (DQ width) is 16 bits.
- The maximum supported DQ group size in Max 10 is 8bits.
- So, there will be 2 group of data (DQS) which is 8 bits + 8bits =16 bits.
To summarize based on above example:
- Total interface width = 16 bits
- DQ/DQS group size = 8 bits per DQS group
- Number of DQS group = 2
Hope this helps.
Aida
Hi Susmita,
It’s me Aida. Hope you still remember me. Glad to serve you again. 😊
Kindly refer to my reply below.
1. How to calculate the avalon memory mapped data width for any device based on DQ group size?
[Aida]: MAX 10 supports only Half rate, which results in a width of 4× the memory data width.
2. Does Max 10 support x 16 interface?
[Aida]: Yes, but not for all Max 10 devices and packages support x16 interface. Refer to Max 10 EMIF handbook under section Table 2-2: Supported Maximum External Memory Interface Width in MAX 10 Device Packages for MAX 10 device packages support that support x16 interface.--> https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_emi.pdf
3. If yes, what is the maximum of DQ groups in MAX 10?
[Aida]: The maximum DQ group is x8 data.
Hope this helps. Let me know if there are any concern/questions.
Aida
