TNine
7 years agoWhat is the appropriate way to specify the SDC for "..was determined to be a clock but was found without an associated clock assignment."
I already read https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an545.pdf?language=en_US and https://forums.intel.com/s/question/0D50P00003yyHQNSA2/diagnosing-signal-was...
sstrell
7 years agoYou set signal a (aka stableA) as a new clock domain for the rotaryEncoder, so it must be constrained with a generated clock constraint. stableA is based off metaA and metaA is based off enc_a, so metaA is a generated clock as well. Something like this would work:
create_generated_clock -source [get_ports enc_a] -multiply_by 1 [get_pins <register that creates metaA>|q] -name metaA
create_generated_clock -source [get_pins <register that creates metaA>|q] -multiply_by 1 [get_pins <register that creates stableA>|q] -name stableA
The set_clock_groups command only prevents analysis for data transfers between the two clock domains you mention. It does not constrain the clock that drives the rotaryEncoder.
#iwork4intel
