Weak pull-ups \ tri-state at cyclone v soc
- FvM
- Hi,
connecting 10k pull-down to nconfig isn't correct. The pin should have a pull-up resistor and temporarily pulled down to trigger reconfiguration.
- Ophir_eng
Hi, thanks you for the comment
We have constant pull-up on nconfig so nconfig always at high position
Some of our outpus with pull down (to make sure that the en of the power supply will be at low position until the fpga will power up and enable the power supplies according our sequence), we saw at the oscilloscope that the en assert to high to 2-3 sec and then goes low
- Hi,
- AqidAyman_Altera
In the Cyclone V Pin Connection Guideline, it mentioned:
When you use the nCONFIG pin in a passive configuration scheme, connect the pin directly to the
configuration controller. When you use the nCONFIG pin in an AS configuration scheme, connect
the pin through a 10-kΩ resistor tied to VCCPGM. When you do not use the nCONFIG pin, connect
the pin directly or through a 10-kΩ resistor to VCCPGM.
- AqidAyman_Altera
I hope the previous response was sufficient to help you proceed. As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
