MHar-
6 years agoWe are using arm angstrom linux system for the Cyclone V . What do we need to add in order to respose to a UDP Broadcast command?
FawazJ_Altera
6 years agoHello,
Since you are running linux on board, you can use some linux commands to control the ethernet stream. I would start with tcpdump. If you cannot find tcpdump command, you might need to install it:
opkg install tcpdump
More information about this command can be found here:
https://www.tcpdump.org/manpages/tcpdump.1.html
Hope this might help.
Thank you
