warning 18584 There are no transceivers channels used in the design
I have an Arria 10 (10AX027H4F34E3SG)
PC: Windows 10
- Quartus standard 20.1.10.711
-Quartus Pro 21.1.0.169
In both softwares, I get similar warnings:
Warning (18584): There are no transceiver channels used in the design. You must use or instantiate atleast 1 transceiver channel to preserve the rest of unused channels.
Critical Warning (17951): There are 24 unused RX channels in the design. If you intend to use any of these channels in the future, you must add the assignment 'set_instance_assignment -name PRESERVE_UNUSED_XCVR_CHANNEL ON -to <pin_name>' in your QSF file. This assignment will preserve the performance of specified channels over time. Note that unused channel preservation only works if the design uses or instantiates atleast 1 transceiver channel.
I modified the .qsf file with the following:
set_instance_assignment -name PRESERVE_UNUSED_XCVR_CHANNEL ON -to AL30
and other transceiver lines
But in the pro version, I get an error during the compilation:
Error(17950): Pin corresponding to CLKUSR has not been reserved in the device. Cannot perform unused RX clock workaround.
I followed the suggestion:
https://www.intel.com/content/www/au/en/support/programmable/articles/000080648.html
but I still get the same compilation error. What am I missing?
Cheers
I have compiled your design in quartus pro v21.1 and the warning is clear "Warning(18584): There are no transceiver channels used in the design. You must use or instantiate at least 1 transceiver channel to preserve the rest of the unused channels". You need to instantiate minimum 1 transceiver channel with fPLL and reset controller. This should resolve your problem. Please let me know if you still face any issues.
Thank you
Kshitij Goel
- Kshitij_Intel
Thank you for sharing the designs. I will see and will get back to you soon.
Thank you
Kshitij Goel
- Kshitij_Intel
Thank you
Kshitij Goel
- Kshitij_Intel
Any update on this.
Thank you
Kshitij Goel
- Kshitij_Intel
As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Thank you
Kshitij Goel
