16 years agoWant a daughter card with DC signals
Hey guys, I am searching for a ADA daughter card for my cyclone 3 dev board. Particularly I want it to be able to capture DC analog input and generate DC analog ouput, because I am going to use it...
16 years agothe ADC is the ad7928
http://www.analog.com/static/imported-files/data_sheets/ad7908_7918_7928.pdf the DAC is the the ad5025 http://www.analog.com/static/imported-files/data_sheets/ad5025_5045_5065.pdf Powered from 5V from the DE0, so its range is 0-5V. The one issue I have is that its SNR isn't extraordinary (like just 55db at full amplitude), due mainly to the noise on the DE0 board's supply rails.
