smile123
2 years agoW25Q128 is used to remote update for arria v
Hi,everyone,i have some question about remote update,below are details: 1. I used w25q128 flash for 5AGTFD3H3F35I3 and 5AGXMA3D4F31I3. 2. The flash storage boot and app,but the program is failed to...
NurAiman_M_Intel
2 years agoHi,
W25Q128 is not tested by Intel, hence we are not sure of it functionality.
You can refer to the link below for recommended configuration device for Arria V.
In Remote update userguide also have the information for the supported flash:
Aiman
- FvM2 years ago
according to my experience, Winbond W25Qxxx devices work well as AS memory. Flash ID check has to be disabled in programming file converter. According to your description, a dual boot design is failing in your test, there are many possible reasons why this happens. Did you try with basic single configuration and .jic programming? - smile1232 years ago
HI,thanks for your reply.
Is the MT25QL256ABA1EW9-0SIT flash suitable the 5AGTFD3H3F35I3 and 5AGXMA3D4F31I3?
the 《Table 4 - Intel Supported Third Party Configuration Devices》 recommend the MT25QL256ABA8ESF-0SIT,this is 16 pin,but my pcb is 8 pin,can use the MT25QL256ABA1EW9-0SIT?
