VREFB<#>N0 pin connectivity on MAX10
I am doing a design with MAX10 FPGA (10M25DAF484I). I am using both the internal ADC IPs and i have connected the ADC_VREF pin to a reference 2.5V power supply.
Right now i have not connected VREFB1N0, VREFB2N0, VREFB3N0, VREFB4N0, ...VREFB8N0. Can i leave all the VREFB<#>N0 pins unconnected? Or what should be the recommended connectivity?
The connection guidelines document says that: "If you are not using the VREF pins in banks or shared banks, connect unused pins as defined in the Intel Quartus Prime software" But i don't have any Quartus software installed to check.
I need to freeze on the hardware quickly. So please reply.
- EngWei_O_Intel
Hi Nagendra SV You can refer to Pin Connection Guidelines: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf To set up the unused pins behaviour: In Quartus Prime tools, Go to Assignments -> Device -> Device and Pin Options -> Unused Pins tab and set the behaviour of unused pins. Thanks. Regards Eng Wei- MartinMaa
Hello, I have the same questions about these pins.
What is the purpose of these pins, what are the signal specifications,
and when are these pins required?How can voltage be applied to these pins?
If these pins are not in use, how should they be handled?Thank you for your response.
- EngWei_O_Intel
Hi Nagendra SV
Do you have any question regarding the unused pins before we proceed to close the ticket?
Eng Wei
