NSV00
6 years agoVREFB<#>N0 pin connectivity on MAX10
I am doing a design with MAX10 FPGA (10M25DAF484I). I am using both the internal ADC IPs and i have connected the ADC_VREF pin to a reference 2.5V power supply. Right now i have not connected VREFB...
EngWei_O_Intel
6 years agoHi Nagendra SV
You can refer to Pin Connection Guidelines:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/PCG-01018.pdf
To set up the unused pins behaviour:
In Quartus Prime tools,
Go to Assignments -> Device -> Device and Pin Options -> Unused Pins tab
and set the behaviour of unused pins.
Eng Wei
MartinMaa
2 years agoHello, I have the same questions about these pins.
What is the purpose of these pins, what are the signal specifications,
and when are these pins required?
How can voltage be applied to these pins?
If these pins are not in use, how should they be handled?
Thank you for your response.
