15 years agoviewing the de-2 board clock on the agilent 16821 logic analyzer during state-mode
Hi, How to view the DE-2 50 MHz clock on the waveform of 16821 Agilent Logic Analyzer during the state-mode? I use assign statement to output the DE-2 board clock to the GPIO[0] pin. Then ...
15 years agoDo you have set clk trigger to both clock edges or can it be set this way?
Can you do this kind of test where are also 25 MHz clk in captured data? If input clk is 50 MHz then captured data should be like "01010101"
