zasas's avatar
zasas
7 years ago
(VHDL) Help...I set the timer counter code. I want to reset the circuit by pressing it more than 2 seconds. How do I write code?
USE ieee.std_logic_unsigned.all;
ENTITY TIMER1 IS
digit1, digit2, digit3, clk_period: OUT STD_LOGIC_VECTOR(7 DOWNTO 0));
END TIMER1;
ARCHITECTURE TIMER1 OF TIMER1 IS
SIGNAL Hzclk : STD_LOGIC;
SIGNAL s1: INTEGER RANGE 0 TO 10
SIGNAL s2: INTEGER RANGE 0 TO 6;
SIGNAL minutes: INTEGER RANGE 0 TO 10;
BEGIN
PROCESS (clk)
VARIABLE count : INTEGER RANGE 0 TO fclk;
BEGIN
IF (clk'EVENT AND clk='1') THEN
count := count +1;
IF (count=fclk/2) THEN
Hzclk <= '1';
ELSIF (count=fclk) THEN
Hzclk <= '0';
count := 0;
END IF;
END IF;
END PROCESS;
PROCESS (Hzclk, rst)
VARIABLE count1: INTEGER RANGE 0 TO 10;
VARIABLE count2: INTEGER RANGE 0 TO 6;
VARIABLE count3: INTEGER RANGE 0 TO 10;
BEGIN
IF (rst ='1'AND ) THEN
after(20ns);
count1 :=0;
count2 :=0;
count3 :=0;
ELSIF (clk'EVENT AND clk='1') THEN
IF (startstop='1' AND (count1/=9 OR count2/=5 OR count3/=9)) THEN
count1 := count1 +1 ;
IF (count1=10) THEN
count1 := 0;
count2 := count2 + 1;
IF (count2=6) THEN
count2 := 0;
count3 := count3 +1;
END IF;
END IF;
END IF;
END IF;
s1 <= count1;
s2 <= count2;
minutes <= count3;
END PROCESS;
PROCESS (s1, s2, minutes)
BEGIN
CASE s1 IS
WHEN 0 => digit1 <= "11111100";
WHEN 1 => digit1 <= "01100000";
WHEN 2 => digit1 <= "11011010";
WHEN 3 => digit1 <= "11110010";
WHEN 4 => digit1 <= "01100110";
WHEN 5 => digit1 <= "10110110";
WHEN 6 => digit1 <= "10111110";
WHEN 7 => digit1 <= "11100000";
WHEN 8 => digit1 <= "11111110";
WHEN 9 => digit1 <= "11110110";
WHEN OTHERS => NULL;
END CASE; CASE s2 IS
WHEN 0 => digit2 <= "11111100";
WHEN 1 => digit2 <= "01100000";
WHEN 2 => digit2 <= "11011010";
WHEN 3 => digit2 <= "11110010";
WHEN 4 => digit2 <= "01100110";
WHEN 5 => digit2 <= "10110110";
END CASE;
CASE minutes IS
WHEN 0 => digit3 <= "11111100";
WHEN 1 => digit3 <= "01100001";
WHEN 2 => digit3 <= "11011011";
WHEN 3 => digit3 <= "11110011";
WHEN 4 => digit3 <= "01100111";
WHEN 5 => digit3 <= "10110111";
WHEN 6 => digit3 <= "10111111";
WHEN 7 => digit3 <= "11100001";
WHEN 8 => digit3 <= "11111111";
WHEN 9 => digit3 <= "11110111";
END CASE;
END PROCESS;
END TIMER1;
1 Reply
  • AnandRaj_S_Intel's avatar
    AnandRaj_S_Intel
    Hi @zasas​
    Okay, You have to build a counter which will count to 25 million to get 2 second events which will be used for reset.
    You can refer below example and use it in you design.
    Please note that I have not checked your code.
    PROCESS (Clock)
    BEGIN
    IF (Clock'EVENT AND Clock = '1') THEN
        counter <= counter + '1';
        if( counter = <NUMBER>) then --<NUMBER> =How many clocks will you need to get two second? Well it will be clearly 25 million cycles assusing clock of 50MHz.
            reset<= '1';
            counter <= "0";
        else
            reset<= '0';
        end if;
    END IF;
    END PROCESS;
    Anand
