15 years agoVery High speed serial communication using the STRATIX II GX FPGA
Hi, We have the stratix II GX EP2SGX90F1508C3 FPGA Board and now want to develop a system that works as very high speed serial Interface using the transceivers present in the FPGA. For thi...
15 years ago --- Quote Start --- Check out SerialLite II also. It is a very thin layer on top of the transceivers and very easy to use. You can also turn on fancy stuff like CRCs. It supports both one-to-one and broadcast messaging. The IP is free with a full license of Quartus. I have used the transceivers through the HSMC connector, but have no experience with the SFP. --- Quote End --- Thank you very much for your reply.... I will try SerialLite II also. >> I have used the transceivers through the HSMC connector, but have no experience with the SFP. Means you have used the Transceivers TXP TXN RXP RXN pins through the HSMC connectors I think I am right....
