15 years agoverify failed between address 0xXX and 0xXX
hi:
the problem I meet while run the NIOSII ESD 10.0 sp1. verify failed between address 0xXX and 0xXX; the address belongs to the sdram,I have check my project to make sure the dq[15..0] is bir-director and the connection is solid and so on... the problem is still there. So, I want to ask if the custom component of SOPC is the reason or not ?? I have add a SOPC component written of my own,but the quartusII project compiled successfully. best regard1 Reply
Hi
I had similar behaviour. It was the watchdog (of my own) which resets NIOS cpu. Please, describe more : You program the Flash ROM or you just download programm into RAM ?
