Using get_entity_instances properly in reusable sdc files
I would like to write reusable sdc exceptions for components that can be shared accross several projects.
The get_entity_instances command seems to be what I am looking for but I'm face issues with it, as I'm not a tcl expert.
I have started with something like this :
set myList [get_entity_instances -nowarn MyEntity] foreach elem $myList { # This command is ok set_multicycle_path -from "$elem|myVect[0]" -to "$elem|mySignal" -setup 2 # This command is wrong because curly braces prevent variable evaluation set_multicycle_path -from {$elem|myVect[*]} -to {$elem|mySignal} -setup 2 # This command reports unmatching keeper/pin/etc set_multicycle_path -from "$elem|myVect[*]" -to "$elem|mySignal" -setup 2 }
My question is : how should I write these commands to use vectors ?
Edit : it seems it was not working because my constraint had the first form :
# This constraint fails set_multicycle_path -from "$elem|SUBMODULE:submodule|myVect[*]" -to "$elem|mySignal[*]" -hold 2 # This constraint is ok set_multicycle_path -from "$elem|submodule|myVect[*]" -to "$elem|mySignal[*]" -hold 2
- RichardT_altera
Is my understanding correct that you want to have a component that has its own SDC file so you can use it in multiple projects? Like an IP component that is able to generate its own SDC constraint.
Have you been able to solve the issue by yourself? It seems that you have the constraints working.
Richard Tan
- RichardT_altera
Dropping a note to ask if my last reply was helpful to you?
Do you need any further assistance from my side?
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
- RichardT_altera
If you have any further questions or concerns, please don't hesitate to let us know.
Richard Tan
