Using ADC feature and JTAG @ 3.3V
Dear Sirs,
I have a project using a Max 10 device (10M08DAF256) and I wish to use the ADC feature and I have the JTAG interface at 3.3V (the Max device will be in a programming chain), so the VCCIO1B should be at 3.3V.
In some document I read this statements:
a) If you do not enable the ADC feature, you may
connect VCCIO1A and VCCIO1B pins to different
voltage levels, provided that the VREF pin is not
used. If the VREF pin is used, you must connect
the VCCIO1A and VCCIO1B pins to the same
voltage level;
b) If you enable the ADC feature, connect
VCCIO1A and VCCIO1B to 2.5-V.
From the statement b), I deduct I can't use the ADC feature and JTAG at 3.3V; from the statement a) instead I infer I can connect VCCIO1A at 2.5V and VCCIO1B at 3.3V.
The question is: it is possible to use the ADC feature and JTAG @ 3.3V if I set the VCCIO1A at 2.5V and VCCIO1B at 3.3V?
Further,: the VREF pin mentioned in the statement a) is the VREF for voltege referenced IO, or is the ADC Vref?
Thank you very much in advance.
Marco
1 Reply
- Rahul_S_Intel1
Hi Macro,
The below is for line page no:14
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/dp/max-10/pcg-01018.pdf
>>Yes
The VCCIO1B have to be power up with 2.5V if ADC is been enabled and JTAG pin have to supply have to be with compactable supply.
Rs
Page no: 21 onwards use cases are shown
and
