16 years agoUSB programmer
Hello everyone, I want to design a low cost development board for the Altera Max CPLD's. I plan to do the programming through a USB port as the parallel and the serial ports are not available o...
16 years agoMaxII CPLDs are programmed via JTAG
what you request are the schematics of the usb blaster, and the logic inside the pld between the USB chip (FTDI 245 for example) and the JTAG IF that goes to your target.. The source for the pld will be a problem due to copyrights
