USB Mass storage device - Save data to file
- 2 years ago
Probably that'll be easier by looping back the data and writing into text file using python.
Sheng
The Verilog File IO Operations usually being used/worked for testbench check this link https://www.chipverify.com/verilog/verilog-file-io-operations
If you want to run something on the board and output to be saved in a txt file, probably need to use embedded system. Here is a video link for your reference https://www.youtube.com/watch?v=kbIcXwtfBiY&t=414s
Sheng
- antonto2 years ago
Thank you for your response, i saw the video that you sent me and it was actually quite good I didnt know that you could do that. Sadly it uses C and i can only use python and SystemVerilog on my project. My project is basically to combine two boards, the DE10-Lite and SAMD21 M0. The SAMD21 board will send the inputs to the DE10-Lite which will do something and the goal was to save the output to a txt file. But now im thinking if i send the output back to the SAMD21 and then save it to a txt file wouldn't that be easier? Please tell me your opinion and will keep you updated after i do some testing.
