USB Blaster II [3-3] vs [1-10.2]
What is the difference between the numbers [3-3] vs [1-10.2] after the USB Blaster II banner?
I am having an issue with a customer not able to load a CMF file into an Agilex FPGA. When customer launches jtagconfig -d, they banner they get with USB Blaster II launch is:
Whereas when I run jtagconfig -d, the USB blaster II banner I get is:
USB Blaster II [1-10.2]
- YuanLi_S_Intel
Hi, may i know how do you load the CMF? You using command line in command shell or quartus programmer? Can you share me the steps?
- cbhowmik
Thank you for your response.
I was loading the CMF using System Console using command from TCL script: debug_send_bitstream_with_fuse_blown <cmf file>.
I was finally able to use the Quartus programmer command line to convert a CMF to RBF file and load the RBF file using command line quartus_pgm. Since the RBF included the CMF, I was finally successful in loading the desired CMF for the customer.
I also found out that the numbers in square brackets in the USB Blaster II [3-3] represents the USB Cable port that the Blaster is connected to.
At this point, I can close this question. However there are still open questions on the System Console Software version between what I am using vs the customer since we were not able to load the CMF using System Console that customer was using but I was able to load at my end.
- YuanLi_S_Intel
Is the quartus version used the same between you and ur customer? Is there any error messages when you run the TCL script?
- cbhowmik
The Quartus versions are exactly the same. The error message indicates the loader timed out. It loads 90% of the bytes/words and then times out. I don't have a screenshot of the exact error message unfortunately.
- YuanLi_S_Intel
If possible, please add some delay in your TCL in the interval of the command. Sometimes it might cause issue because of this.
