USB Blaster II [3-3] vs [1-10.2]
Thank you for your response.
I was loading the CMF using System Console using command from TCL script: debug_send_bitstream_with_fuse_blown <cmf file>.
I was finally able to use the Quartus programmer command line to convert a CMF to RBF file and load the RBF file using command line quartus_pgm. Since the RBF included the CMF, I was finally successful in loading the desired CMF for the customer.
I also found out that the numbers in square brackets in the USB Blaster II [3-3] represents the USB Cable port that the Blaster is connected to.
At this point, I can close this question. However there are still open questions on the System Console Software version between what I am using vs the customer since we were not able to load the CMF using System Console that customer was using but I was able to load at my end.
