URGENT NEED OF INFORMATION - CRE_ITEMMASTER_20221215
Hello Team ,
Good day..
This is Parag from Component Engineering , Flex – India. We are working on some of your manufacturing parts and require information in the attached excel file.
Please help us to complete the table by filling it with correct information.
Please note that DATASHEET LINK/PDF is mandatory for us to proceed further.
NOTE :- If you are not the correct contact person then please help us to get to the correct person.
Your soon response will be highly appreciated.
End Customer: CRESTON
Flex Manufacturing Site: Gaud South (Mexico)
ITEM NUMBER - CREH-2050721
MPN_DESCRIPTION - IC, PROG LOGIC, ARRIA 10 FPGA, 10AS048E,480K LE,12XCVRS SP3,EXT TMP,FSP2,LP,FBGA-780,SM
MANUFACTURER PART NUMBER - 10AS048E3F29E2LG
1. LIFE CYCLE STATUS (ACTIVE OR OBSOLETE OR NRND) ?
2. IF NRND, PLEASE PROVIDE LTB AND LTS DATE
3. IF OBSOLETE, SUGGEST EXACT DROP-IN REPLACEMENT
4. IS THIS PART AVAILABLE IN TAPE&REEL PACKAGING (YES/NO).?
5. IF YES, PROVIDE CORRECT ORDERABLE TAPE AND REEL PART NUMBER
6. DESCRIPTION MATCHES WITH MPN (YES/NO) ?
7. GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT/ INVALID ?
8. IF NO SUGGEST CORRECT ORDERABLE MPN
9. MOISTURE SENSITIVITY LEVEL (MSL) ?
10. ROHS COMPLIANT WITHOUT ANY EXEMPTION (YES/NO)?
11. IF NO THEN WHAT IS THE EXACT EXEMPTION ?
12. PACKAGE/CASE SIZE
13. MOUNTING TYPE: (SURFACE MOUNTED/THROUGH HOLE)
14. PACKING TYPE?
15. PART MARKING?
16. DATASHEET/DRAWING SHEET
Parag
1 Reply
- Zawani_M_Intel
Dear PARAGSHENAI,
Thank you for using Intel FPA Community Forum.
We believed there is another duplicate case of this request and we believed the request has been asnwer.
However, we share the answer again here as reference.
IFE CYCLE STATUS (ACTIVE OR OBSOLETE OR NRND) ? : Active
IF NRND, PLEASE PROVIDE LTB AND LTS DATE : -
IF OBSOLETE, SUGGEST EXACT DROP-IN REPLACEMENT : -
IS THIS PART AVAILABLE IN TAPE&REEL PACKAGING (YES/NO).? : TRAY
IF YES, PROVIDE CORRECT ORDERABLE TAPE AND REEL PART NUMBER : -
DESCRIPTION MATCHES WITH MPN (YES/NO) ? : YES
GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT/ INVALID ? : Correct
IF NO SUGGEST CORRECT ORDERABLE MPN : -
MOISTURE SENSITIVITY LEVEL (MSL) ? : 3
ROHS COMPLIANT WITHOUT ANY EXEMPTION (YES/NO) : YES
IF NO THEN WHAT IS THE EXACT EXEMPTION ? : -
PACKAGE/CASE SIZE : Height(2.63), WIdth(29), Length(29)
MOUNTING TYPE: (SURFACE MOUNTED/THROUGH HOLE) : SURFACE MOUNTED
PART MARKING : -
DATASHEET/DRAWING SHEET : https://static6.arrow.com/aropdfconversion/c62f523124b7f65ca7f23d677d9564cfbf400345/attachment.pdf
