URGENT NEED OF INFORMATION - CRE_ITEMMASTER_20221215
Dear PARAGSHENAI,
Thank you for using Intel FPA Community Forum.
We believed there is another duplicate case of this request and we believed the request has been asnwer.
However, we share the answer again here as reference.
IFE CYCLE STATUS (ACTIVE OR OBSOLETE OR NRND) ? : Active
IF NRND, PLEASE PROVIDE LTB AND LTS DATE : -
IF OBSOLETE, SUGGEST EXACT DROP-IN REPLACEMENT : -
IS THIS PART AVAILABLE IN TAPE&REEL PACKAGING (YES/NO).? : TRAY
IF YES, PROVIDE CORRECT ORDERABLE TAPE AND REEL PART NUMBER : -
DESCRIPTION MATCHES WITH MPN (YES/NO) ? : YES
GIVEN MPN IS CORRECT & ORDERABLE / INCORRECT/ INVALID ? : Correct
IF NO SUGGEST CORRECT ORDERABLE MPN : -
MOISTURE SENSITIVITY LEVEL (MSL) ? : 3
ROHS COMPLIANT WITHOUT ANY EXEMPTION (YES/NO) : YES
IF NO THEN WHAT IS THE EXACT EXEMPTION ? : -
PACKAGE/CASE SIZE : Height(2.63), WIdth(29), Length(29)
MOUNTING TYPE: (SURFACE MOUNTED/THROUGH HOLE) : SURFACE MOUNTED
PART MARKING : -
DATASHEET/DRAWING SHEET : https://static6.arrow.com/aropdfconversion/c62f523124b7f65ca7f23d677d9564cfbf400345/attachment.pdf
