15 years agoUnwanted frequency shift in DA-converted signal
Hi, i use Matlab/Simulink and DSP Builder for my project. In Matlab, I generate a digital source signal and program it in a LUT-Block in Simulink. This Block then sends the data to my DACs...
15 years agoIt might not be the issue of continuity, it is just a matter of exclusion.
You may try generate the three frequencies then add them up in hardware rather than pre-added in LUT. I agree phase discontinuity will show as spikes rather than offset. The offset may be explained on basis of clock, heating, timing or bug.
