15 years agoUnwanted frequency shift in DA-converted signal
Hi, i use Matlab/Simulink and DSP Builder for my project. In Matlab, I generate a digital source signal and program it in a LUT-Block in Simulink. This Block then sends the data to my DACs...
15 years agoHow did you generate the LUT? are you aware of wrap-up continuity? I mean for one cycle sinusoid your first sample should not repeat at the end of LUT as you will wrap up to start.
