16 years agoUnable to run lpm_inv
Hello , I have the MAXII Micro kit with the EPM2210F324C3. I have a small schematic project with a simple lpm_inv block. It compiles fine and downloads fine. But I'm unable to see any change ...
16 years agoI was referring to your simulation, that didn't drive the inverter. It works if setup correctly. If you have a problem with the real hardware, there's most likely a different problem, e.g. missing supply voltages. You can see from the compilation results, that the inverter should work.
