Vandana_GS
2 years agoUnable to generate output for 32bit real and imaginary data in hardware implementation for Agilex 7
Hi, I'm trying to do the hardware Implementation for a complex code containing real and imaginary 32 bits. I have two LED PIN options in the agilex board: Terasic Agilex SOM Module FPGA: Agilex AGF...
- 1 year ago
You may view the Signal Tap training video here:
https://learning.intel.com/Developer/learn/learning-plans/245/using-the-signal-tap-logic-analyzer
Additionally, you can refer to the Application Note on how to use it:
Richard Tan
FvM
1 year agoHi,
It's not clear how your signaltap is trigerred and which acquisition is used. May be data are simply sampled at the wrong time.
Vandana_GS
1 year agoHi,
Since I am beginner using Quartus Prime software. please explain the procedure to signal tap trigger and performing acqusition. This will help in properly excuting the hardware implementation.
Thank you
Vandana
