15 years agoUnable to find Valid MAC address
the hardware and software i use are based on“niosii_ethernet_standard_3c25.zip” and“nichestack_tutorial” from altera pages. after running , In NiosII IDE software, console is below: PHY ...
15 years agoThe software in NIOSII IDE is based on Simple_socked_server,I want to kown the communication mechanism clearly,so I post serveral stupid questions below,thanks for your help!!!
in iniche_init.c: 1: the funtion "get_board_mac_addr()"seems to get MAC address for nichestack tcp/ip stack system,the MAC address is the address of tse controller,these MAC address are placed in Flash memory,It means that I should write address into Flash,but how to realize it? the error "Invalid MAC Address stored at Flash Offset 0x8000",maybe generated by that. 2:according to the .pdf ,the NEEK development board acts as DHCP client,so the PC acts as DHCP server,I connect NEEK and PC directly,and try to run a DHCP server software on PC. the error "DHCP timed out, going back to default IP address(es)"maybe generated by that. has somebody ever used sss tenplate ? what i analyse above are right ? thanks
