Harsha4
1 year agoUnable to detect 100Hz input signal properly
Hi, We are using cyclone10lp in one of our design. In that design, we are trying to take a 100Hz clock input and use it for some application but as soon as it enters FPGA the signal is getting rand...
FvM
1 year agoHi,
I was under the assumption that Schmitt-Trigger function is supported with Cyclone 10 LP for all I/Os, but that's only the case for MAX 10 FPGA series.
Possible options for Cyclone 10 LP are
- external Schmitt-Trigger
- digital debounce logic, suppressing succeeding edges for a certain time period after first rising or falling edge
- implement the 100 Hz input as bidirectional inout pin with disabled output and enable bus-hold feature, can work as Schmitt-Trigger emulation in combination with source impedance.
