leondietrich
5 years agoUnable to access HPS periphery on Agilex chip
Hi there,
We are using the Intel Agilex dev kit v3. We've instantiated the HPS together with some memory mapped IO components (Have a look at the attached screenshot of QSYS) and try to Boot linux ...
leondietrich
4 years agoHi Aik Eu,
unfortunately we had to reschedule the corresponding research project to December. The reason why we use the two different documents
is due to the fact that the latter document is explicitly stated as to be only compatible with the transceiver development kit but
not with the F-Series development kit. The first tutorial was stated to be compatible with both thus we mixed them.
We are going to try to rebuild the SD image on November the 30th and will report back if it worked using your suggestion or not.
Sincerely
Leon Dietrich
