16 years agouboot on cyclone III(EP3C25) Nios development kit
Hi, I am having issues with downloading uboot on NIOS processor.I am following the steps mentioned in "http://nioswiki.com/DasUBoot". As the EP3C25 Nios 2 development kit is not supported, I had t...
16 years agoIt seems like the clock is not given, or been reset.
Are you using jtag-uart or uart? I think you can use one or the other. CONFIG_SYS_NIOS_CONSOLE is the place to set. Be aware, if you are using mmu, your address is either 0xE******* or 0xF******* BTW, Do you have your own project folder at "board/altera/ep3c25/your_folder/all_files" You might want to copy all from similar projects and change them. Your question b) seems like incorrect to me.
