srimathi's avatar
srimathi
1 year ago
UART functionality in altera max II EMP240 CPLD
Hi everyone,
I'm currently working on implementing UART communication on an Altera MAX II CPLD using Verilog. As I'm still learning, I would really appreciate it if anyone could share UART transmitter and receiver Verilog code. Thanks in advance.
  • KennyT_altera's avatar
    KennyT_altera
    I'll provide you with synthesizable UART transmitter and receiver Verilog code suitable for Altera MAX II CPLD implementation. But you will need to write your testbench to test out the code:
    ## UART Transmitter
    ```verilog
    module uart_tx #(
    parameter CLOCK_FREQ = 50000000, // 50 MHz clock
    parameter BAUD_RATE = 9600 // 9600 baud
    input clk,
    input rst_n,
    input [7:0] tx_data,
    input tx_start,
    output reg tx,
    output reg tx_busy
    localparam BAUD_TICKS = CLOCK_FREQ / BAUD_RATE;
    localparam COUNTER_WIDTH = $clog2(BAUD_TICKS);
    reg [COUNTER_WIDTH-1:0] baud_counter;
    reg [3:0] bit_counter;
    reg [9:0] tx_shift_reg; // Start bit + 8 data bits + Stop bit
    reg baud_tick;
    // Baud rate generator
    always @(posedge clk or negedge rst_n) begin
    if (!rst_n) begin
    baud_counter <= 0;
    baud_tick <= 1'b0;
    end else begin
    if (baud_counter == BAUD_TICKS - 1) begin
    baud_counter <= 0;
    baud_tick <= 1'b1;
    end else begin
    baud_counter <= baud_counter + 1;
    baud_tick <= 1'b0;
    end
    end
    end
    // UART transmitter state machine
    if (!rst_n) begin
    tx <= 1'b1; // Idle high
    tx_busy <= 1'b0;
    bit_counter <= 0;
    tx_shift_reg <= 10'h3FF; // All ones (idle)
    end else begin
    if (tx_start && !tx_busy) begin
    tx_shift_reg <= {1'b1, tx_data, 1'b0}; // Stop + Data + Start
    tx_busy <= 1'b1;
    bit_counter <= 0;
    end else if (tx_busy && baud_tick) begin
    tx <= tx_shift_reg[0];
    tx_shift_reg <= {1'b1, tx_shift_reg[9:1]};
    if (bit_counter == 9) begin
    tx_busy <= 1'b0;
    bit_counter <= 0;
    end else begin
    bit_counter <= bit_counter + 1;
    end
    end
    end
    end
    endmodule
    ## UART Receiver
    ```verilog
    module uart_rx #(
    input clk,
    input rst_n,
    input rx,
    output reg [7:0] rx_data,
    output reg rx_valid
    localparam HALF_BAUD_TICKS = BAUD_TICKS / 2;
    reg [7:0] rx_shift_reg;
    reg baud_tick;
    reg rx_sync1, rx_sync2; // Synchronizer for rx input
    // Input synchronizer
    if (!rst_n) begin
    rx_sync1 <= 1'b1;
    rx_sync2 <= 1'b1;
    end else begin
    rx_sync1 <= rx;
    rx_sync2 <= rx_sync1;
    end
    end
    // State machine states
    localparam IDLE = 2'b00;
    localparam START = 2'b01;
    localparam DATA = 2'b10;
    localparam STOP = 2'b11;
    reg [1:0] state;
    // Baud rate counter
    if (!rst_n) begin
    baud_counter <= 0;
    baud_tick <= 1'b0;
    end else begin
    if (state == IDLE) begin
    baud_counter <= 0;
    baud_tick <= 1'b0;
    end else if (baud_counter == BAUD_TICKS - 1) begin
    baud_counter <= 0;
    baud_tick <= 1'b1;
    end else begin
    baud_tick <= 1'b0;
    end
    end
    end
    // UART receiver state machine
    if (!rst_n) begin
    state <= IDLE;
    bit_counter <= 0;
    rx_shift_reg <= 0;
    rx_data <= 0;
    rx_valid <= 1'b0;
    end else begin
    rx_valid <= 1'b0; // Default: no valid data
    case (state)
    IDLE: begin
    if (!rx_sync2) begin // Start bit detected
    state <= START;
    baud_counter <= 0;
    end
    end
    START: begin
    if (baud_counter == HALF_BAUD_TICKS) begin
    if (!rx_sync2) begin // Confirm start bit
    state <= DATA;
    bit_counter <= 0;
    baud_counter <= 0;
    end else begin
    state <= IDLE; // False start bit
    end
    end
    end
    DATA: begin
    if (baud_tick) begin
    rx_shift_reg <= {rx_sync2, rx_shift_reg[7:1]};
    if (bit_counter == 7) begin
    state <= STOP;
    bit_counter <= 0;
    end else begin
    end
    end
    end
    STOP: begin
    if (rx_sync2) begin // Valid stop bit
    rx_data <= rx_shift_reg;
    rx_valid <= 1'b1;
    end
    state <= IDLE;
    end
    end
    endcase
    end
    end
    endmodule
    ## Top-Level UART Module
    ```verilog
    module uart_top #(
    input clk,
    input rst_n,
    // TX interface
    input tx_start,
    output tx_busy,
    output uart_tx,
    // RX interface
    input uart_rx,
    output [7:0] rx_data,
    output rx_valid
    uart_tx #(
    .CLOCK_FREQ(CLOCK_FREQ),
    .BAUD_RATE(BAUD_RATE)
    ) tx_inst (
    .clk(clk),
    .rst_n(rst_n),
    .tx_data(tx_data),
    .tx_start(tx_start),
    .tx(uart_tx),
    .tx_busy(tx_busy)
    uart_rx #(
    ) rx_inst (
    .clk(clk),
    .rst_n(rst_n),
    .rx(uart_rx),
    .rx_data(rx_data),
    .rx_valid(rx_valid)
    endmodule
    ## Key Features
    - **Parameterizable**: Clock frequency and baud rate can be configured
    - **Synchronous Design**: Uses proper clock domain design suitable for MAX II
    - **Input Synchronization**: RX input is properly synchronized to avoid metastability
    - **Standard UART Protocol**: 1 start bit, 8 data bits, 1 stop bit, no parity
    - **Handshaking**: TX has busy signal, RX has valid signal
    ## Usage Example
    ```verilog
    // Instantiate in your top-level design
    uart_top #(
    .CLOCK_FREQ(50000000), // 50 MHz
    .BAUD_RATE(115200) // 115200 baud
    ) uart_inst (
    .clk(clk_50mhz),
    .rst_n(reset_n),
    .tx_data(data_to_send),
    .tx_start(send_enable),
    .tx_busy(uart_busy),
    .uart_tx(uart_tx_pin),
    .uart_rx(uart_rx_pin),
    .rx_data(received_data),
    .rx_valid(data_ready)
  • FvM's avatar
    FvM
    compiling the Verilog uart code, I see multiple drivers for baud_counter in uart_rx module. Can be fixed by merging Baud rate counter and UART receiver state machine always blocks.
    Frank
    • srimathi's avatar
      srimathi
      Is that code is working for you, I barely see any waveform on the tx line.
    KennyT_altera
    How about try the below:
    module uart_rx #(
    input clk,
    input rst_n,
    input rx,
    output reg rx_valid
    reg baud_tick;
    if (!rst_n) begin
    rx_sync1 <= 1'b1;
    rx_sync2 <= 1'b1;
    end else begin
    rx_sync1 <= rx;
    end
    end
    reg [1:0] state;
    // Combined baud counter and UART receiver state machine
    if (!rst_n) begin
    state <= IDLE;
    bit_counter <= 0;
    rx_shift_reg <= 0;
    rx_data <= 0;
    rx_valid <= 1'b0;
    baud_counter <= 0;
    baud_tick <= 1'b0;
    end else begin
    baud_tick <= 1'b0; // Default: no baud tick
    case (state)
    IDLE: begin
    baud_counter <= 0;
    state <= START;
    baud_counter <= 0;
    end
    end
    START: begin
    state <= DATA;
    bit_counter <= 0;
    baud_counter <= 0;
    end else begin
    end
    end else begin
    end
    end
    DATA: begin
    baud_counter <= 0;
    baud_tick <= 1'b1;
    state <= STOP;
    bit_counter <= 0;
    end else begin
    end
    end else begin
    end
    end
    STOP: begin
    baud_counter <= 0;
    baud_tick <= 1'b1;
    rx_valid <= 1'b1;
    end
    state <= IDLE;
    end else begin
    end
    end
    endcase
    end
    end
    endmodule
    You're correct! The issue is that both the baud rate counter logic and the state machine are trying to drive the `baud_counter` signal, creating multiple drivers. Here's the fixed UART receiver code with the two always blocks merged:
    ## Fixed UART Receiver Code
    ```verilog
    module uart_rx #(
    input clk,
    input rst_n,
    input rx,
    output reg rx_valid
    reg baud_tick;
    if (!rst_n) begin
    rx_sync1 <= 1'b1;
    rx_sync2 <= 1'b1;
    end else begin
    rx_sync1 <= rx;
    end
    end
    reg [1:0] state;
    if (!rst_n) begin
    state <= IDLE;
    bit_counter <= 0;
    rx_shift_reg <= 0;
    rx_data <= 0;
    rx_valid <= 1'b0;
    baud_counter <= 0;
    baud_tick <= 1'b0;
    end else begin
    case (state)
    IDLE: begin
    baud_counter <= 0;
    state <= START;
    baud_counter <= 0;
    end
    end
    START: begin
    state <= DATA;
    bit_counter <= 0;
    baud_counter <= 0;
    end else begin
    end
    end else begin
    end
    end
    DATA: begin
    baud_counter <= 0;
    baud_tick <= 1'b1;
    state <= STOP;
    bit_counter <= 0;
    end else begin
    end
    end else begin
    end
    end
    STOP: begin
    baud_counter <= 0;
    baud_tick <= 1'b1;
    rx_valid <= 1'b1;
    end
    state <= IDLE;
    end else begin
    end
    end
    endcase
    end
    end
    endmodule
    ## Key Changes Made
    1. **Merged Always Blocks**: Combined the separate baud counter and state machine always blocks into a single always block to eliminate multiple drivers for `baud_counter`.
    2. **State-Specific Counter Logic**: The baud counter now resets and increments based on the current state:
    - **IDLE**: Counter is reset to 0
    - **START**: Counter increments until half baud period
    - **DATA/STOP**: Counter increments until full baud period, then resets
    3. **Simplified Baud Tick Generation**: The `baud_tick` signal is now generated inline with the counter logic rather than in a separate process.
    ## Complete Updated Top-Level Module
    The UART transmitter and top-level module remain the same. Just replace the `uart_rx` module with the fixed version above.
    KennyT_altera
    See if the below testbench will help you also?
    `timescale 1ns/1ps
    module tb_uart_top;
    // Parameters
    parameter CLOCK_FREQ = 50000000; // 50 MHz
    parameter BAUD_RATE = 115200; // 115200 baud for faster simulation
    parameter CLK_PERIOD = 20.0; // 50 MHz = 20ns period
    parameter BIT_PERIOD = 1000000000.0 / BAUD_RATE; // Bit period in ns
    // DUT signals
    reg clk;
    reg rst_n;
    // TX interface
    reg [7:0] tx_data;
    reg tx_start;
    wire tx_busy;
    wire uart_tx;
    // RX interface
    reg uart_rx;
    wire [7:0] rx_data;
    wire rx_valid;
    // Test variables
    reg [7:0] test_data_queue[$];
    reg [7:0] received_data_queue[$];
    integer test_count = 0;
    integer error_count = 0;
    // Clock generation
    initial begin
    clk = 0;
    forever #(CLK_PERIOD/2) clk = ~clk;
    end
    // DUT instantiation
    uart_top #(
    ) dut (
    .clk(clk),
    .rst_n(rst_n),
    .tx_data(tx_data),
    .tx_busy(tx_busy),
    .uart_tx(uart_tx),
    .uart_rx(uart_rx),
    .rx_data(rx_data),
    .rx_valid(rx_valid)
    // Task to send a byte via UART TX
    task send_byte(input [7:0] data);
    begin
    @(posedge clk);
    while (tx_busy) @(posedge clk); // Wait for TX to be ready
    tx_data = data;
    tx_start = 1'b1;
    @(posedge clk);
    tx_start = 1'b0;
    test_data_queue.push_back(data);
    $display("Time %0t: Sending byte 0x%02h", $time, data);
    @(posedge clk);
    while (tx_busy) @(posedge clk); // Wait for transmission to complete
    end
    endtask
    // Task to simulate receiving a byte via UART RX
    task receive_byte(input [7:0] data);
    integer i;
    begin
    $display("Time %0t: Simulating RX byte 0x%02h", $time, data);
    // Send start bit (0)
    uart_rx = 1'b0;
    #(BIT_PERIOD);
    // Send 8 data bits (LSB first)
    for (i = 0; i < 8; i = i + 1) begin
    uart_rx = data[i];
    #(BIT_PERIOD);
    end
    // Send stop bit (1)
    uart_rx = 1'b1;
    #(BIT_PERIOD);
    end
    endtask
    // Monitor RX valid data
    always @(posedge clk) begin
    if (rx_valid) begin
    received_data_queue.push_back(rx_data);
    $display("Time %0t: Received byte 0x%02h", $time, rx_data);
    end
    end
    // Task to verify received data
    task verify_received_data();
    reg [7:0] expected, actual;
    begin
    while (test_data_queue.size() > 0 && received_data_queue.size() > 0) begin
    expected = test_data_queue.pop_front();
    actual = received_data_queue.pop_front();
    if (expected == actual) begin
    $display("✓ PASS: Expected 0x%02h, Got 0x%02h", expected, actual);
    end else begin
    $display("✗ FAIL: Expected 0x%02h, Got 0x%02h", expected, actual);
    error_count = error_count + 1;
    end
    test_count = test_count + 1;
    end
    end
    endtask
    // Loopback connection for self-test
    always @(*) begin
    uart_rx = uart_tx;
    end
    // Main test sequence
    initial begin
    // Initialize signals
    rst_n = 1'b0;
    tx_data = 8'h00;
    tx_start = 1'b0;
    uart_rx = 1'b1; // UART idle state
    $display("=== UART Testbench Starting ===");
    $display("Clock Frequency: %0d Hz", CLOCK_FREQ);
    $display("Baud Rate: %0d", BAUD_RATE);
    $display("Bit Period: %0.2f ns", BIT_PERIOD);
    // Reset sequence
    #(CLK_PERIOD * 10);
    rst_n = 1'b1;
    #(CLK_PERIOD * 10);
    // Test 1: Basic loopback test
    $display("\n=== Test 1: Basic Loopback Test ===");
    send_byte(8'h55); // Alternating pattern
    send_byte(8'hAA); // Inverse alternating pattern
    send_byte(8'h00); // All zeros
    send_byte(8'hFF); // All ones
    // Wait for data to be received
    #(BIT_PERIOD * 20);
    // Test 2: ASCII characters
    $display("\n=== Test 2: ASCII Character Test ===");
    send_byte(8'h48); // 'H'
    send_byte(8'h65); // 'e'
    send_byte(8'h6C); // 'l'
    send_byte(8'h6F); // 'o'
    send_byte(8'h20); // ' '
    send_byte(8'h55); // 'U'
    send_byte(8'h41); // 'A'
    send_byte(8'h52); // 'R'
    send_byte(8'h54); // 'T'
    #(BIT_PERIOD * 30);
    // Test 3: Back-to-back transmission
    $display("\n=== Test 3: Back-to-Back Transmission ===");
    for (int i = 0; i < 16; i++) begin
    send_byte(i);
    end
    // Wait for all data to be received
    #(BIT_PERIOD * 50);
    // Test 4: RX-only test (disconnect loopback)
    $display("\n=== Test 4: RX-Only Test ===");
    // Disconnect loopback for manual RX testing
    force uart_rx = 1'b1;
    #(CLK_PERIOD * 5);
    // Manually send some bytes to RX
    release uart_rx;
    receive_byte(8'hA5);
    receive_byte(8'h5A);
    receive_byte(8'h96);
    // Wait and check
    #(BIT_PERIOD * 10);
    // Final results
    #(BIT_PERIOD * 20);
    $display("\n=== Test Results ===");
    $display("Total tests: %0d", test_count + 3); // +3 for RX-only tests
    $display("Errors: %0d", error_count);
    if (error_count == 0) begin
    $display("✓ ALL TESTS PASSED!");
    end else begin
    $display("✗ %0d TESTS FAILED!", error_count);
    end
    $display("\n=== UART Testbench Complete ===");
    $finish;
    end
    // Timeout watchdog
    initial begin
    #(BIT_PERIOD * 1000); // Long timeout
    $display("ERROR: Testbench timeout!");
    $finish;
    end
    // Optional: Dump waveforms
    initial begin
    $dumpfile("uart_tb.vcd");
    $dumpvars(0, tb_uart_top);
    end
    endmodule
    KennyT_altera
    Do you have any further questions? If not, we’ll go ahead and close this thread.
    By the way, please note that we do not provide support for customized code. The code shared above is based on open-source examples and is provided as-is.
    KennyT_altera
    As we do not receive any response from you on the previous answer that we have provided. Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
