Rk_Athram
5 years agoTx_parellel_data does not match Rx_parellel_data
I am using arria10 development kit for my project.
In my project i am using transceivers and speed is 10gbps. Connections are made by referring transceiver user guide.
All signals are prope...
Rk_Athram
5 years ago
tx_digitalreset issue is solved. i have disabled bitslip
1) my rx parallel data keep on changing ,where there is no change is tx parallel data, nor bitslip is implemented.
when this behavior will occur ? is it normal behavior ?
2) I am using dynamic reconfiguration to change profiles,
in simulation it is working fine i can see pll_locked =1, and frequency is also changing.
BUT on board PLL_locked is always 0.
