16 years agoTwo Master RAM Access
Hi i m using NEEK and i m trying to get a hugh amount of Data from an Verilogfile to the NiosII Now i tried to include an Avalon MM Master (Template for Burst Writing) to the SoPC that connect...
16 years agoI forgot to mention... you should give reset values for all your registers. If you don't your component can start in a strange state at power up.
Resetting your HDL with the same signal than the one resetting the SOPC system is recommended.
