16 years agoTwo Master RAM Access
Hi i m using NEEK and i m trying to get a hugh amount of Data from an Verilogfile to the NiosII Now i tried to include an Avalon MM Master (Template for Burst Writing) to the SoPC that connect...
16 years agoThere is nothing wrong in the messages displayed by the IDE. What did you expect?
If your application isn't running, you can check first if it comes from your HDL or not. Something you can try is to recompile everything with your module disabled, and then see if it runs. If it is your component that freezes the system, it could be a good idea to use signaltap probes on its ports to see what it is doing. Did you properly constrain your project and does it meet all timing requirements?
