18 years agoTVP5146 initialization on Video Input Daughtercard
Hi all, Altera's Video Input Daughtercard (as included with the Cyclone II DSP dev kits) uses 2 of the TI TVP5146 TV decoder ICs. The only example design I can find that uses this card is the ...
18 years agoOk if you get the TVP5146 chip datasheet, it has all the I2C addressing documented in it
It is availiable at http://focus.ti.com/lit/ds/symlink/tvp5146.pdf at the moment i'm trying to hook the same card up to a Cyclone III kit using the HSMC E-Gasket to santa-cruz converter. However the only problem i seem to be having is that i can't find information about matching the imedances of the 3.3v card with that of the FPGA. You possibly need to put a series impedance in place to match the line and prevent overvoltage. If you come across anything like that on your stratix II adventure let me know :P
