16 years agoTSE with the dual SGDMA modules...
Hi All, I guess I am uncertain how the TX/RX dma's work on the TSE - specifically I am looking to be able to read a few bytes out of a packet, use these bytes to select a memory mapped data str...
16 years agoThe way that I am transferring data is via a udp socket - I get 2 back-to-back transfers, the first containing a command - (ex a burst data command has a queue number and length). The second transfer is raw data destened to dram. I am using the command transfer decode to build rx descriptors for the sgdma_rx block. Should the transfer simply kick off on the next receipt of data if this was done correctly? I've attached the code if anyone is interested....
Thanks (again) crayner
