15 years agoTSE_MAC to pc
hi: if I want to realize translation from the data in memory on chip to PC through RJ45,The steps I do as follows: 1: sopc system: on chip memory->SGDMA_TX->TSE_MAC to PHY then to RJ45. 2...
15 years agothanks,
the problem is still there ,I suspect that the reason is the corresponding registers of PHY chip(DP8384c) has not been set. because I write code using API which provided by TSE_MAC ,so I refer the altera_avalon_tse.h, altera_avalon_tse.c,the codes in these files are not simple,so ,I donnot know how to utilize them.and donnot know which registers of PHY should be set. I can send you the code I write ,and discuss with each other!~
