15 years agoTSE_MAC to pc
hi: if I want to realize translation from the data in memory on chip to PC through RJ45,The steps I do as follows: 1: sopc system: on chip memory->SGDMA_TX->TSE_MAC to PHY then to RJ45. 2...
15 years agoyou could debug your code to see if you are stuck in a loop or if it is the hardware that is stalling the CPU. If it is the latter, check that the TSE is receiving all its clocks (including the ones on the PHY side).
